misfire from cylinder 1 then went to cylinder 3
When I changed the coil pack from cylinder 1 to cylinder 3 the misfire fallowed. So I thought it would be safe to say it was the ignition coil. Bought a new one and it still misfires in cylinder 3. The ignition coil I bought is the black part that connects the metal piece to the coil pack. Would it now be safe to say it is the metal part that connects to the ignition coil which is the part that has the rubber over it? The car does not shake violently but it does studder in the lower rpms. Cel would flash then turn solid. Wouldnt come right back on when cleared. I am lost..... Any other suggestions, my car is a 97 1.8tq
First what you need is the ultimate tool for your audi-Vag com. If you do not clear your codes first from the ecu your problem will never go away. If you do not have a Vag, then what you can do is remove your ecu for about an 1 1/2 hour from the car after you made all changes to clear codes.
ahaiceman
10-17-2013 03:52 PM
fourwheelslide
03-13-2006 04:43 AM
Quaboosttro
03-03-2006 09:44 AM
KOpork
07-09-2003 05:20 PM
Moneytree26
01-04-2003 01:35 PM
