Misfire problem... Can anyone help me please?
Hi guys,
I have a problem with the A.
Here's the log:
VAG-COM Version: Release 311.2-N
Control Module Part Number: 8D0 907 557 N
Component and/or Version: 1.8L R4/5VT MOTR HS D05
Software Coding: 06201
Work Shop Code: WSC 06325
3 Faults Found:
16684 - Random/Multiple Cylinder Misfire Detected
P0300 - 35-00 - -
16687 - Shareware Version. To Decode all DTCs
P0303 - 35-00 - Please Register/Activate
18014 - Shareware Version. To Decode all DTCs
P1606 - 35-00 - Please Register/Activate
So I've played around and swapped some spark plugs and coil packs... The misfire is only the the third cylinder (P0303)...
My bet, the ICM.
What do you guys think?
Thanks
Mat
Here's the log:
3 Faults Found:
P0300 - 35-00 - -
My bet, the ICM.
Thanks
Mat
Keeper of the Cash
Possibly, since you have a 557-N ECU. That means you have an AEB motor.
<ul><li><a href="https://forums.audiworld.com/a4/msgs/1594531.phtml">Further reading/diags</a></li></ul>
Re: Possibly, since you have a 557-N ECU. That means you have an AEB motor.
Thanks a lot.
You know your things, thanks again!
The car is a 1997 Quattro 1.8t AEB
Keeper of the Cash
Well, I am the king of "STFA", but that's how I found that article
You're not the first to have this issue, and your gut thought was correct.
One last tip: Change the subject line when replying.
You've got the same exact car I do. What color?
Problem solved. Its the ICM, Thanks again Resident Curmudgeon!
Problem solved... No more power for the third cylinder...
I need a new ICM! Yeah!
Well, thanks a lot.
Oh and my car is silver :-)
Well, thanks a lot.
Fast Euro
07-19-2008 07:43 PM
auto3251
12-22-2005 12:24 AM
