Misfires on cyl 3 - 1.8T AEB
Started the car yesterday after a short drive. Barely running.
Diagnostic shows tons of misfires on cyl 3.
- put different coil pack on: no change
- swapped spark plug 1-3: no change
- swapped coil pack 1-3: no change
- swapped ECU: no change
Do the coil packs get the low voltage signal directly from ECU (or is there another Ignition Control Module)?
What to check for first?
Pulled injectors. cleaned with carb cleaner a bit.
Put back in. Engine running on all 4.
Today, running on 3 cyl again. Misfires on cyl 3.
Pulling the plug off injector 3 no effect.
Swapped injector 3 with 1. Same. So its not the injector.
Haven't gotten around to go to Autozone to pick up a noid light, but will do tonight.
Also want to bring a set of new spark plugs. What type/model number should I get?
Stage 3, Giac PC16 tune.
AudiWorld Expert
Put new (copper) spark plugs in. No change.
Pulled no 3 coil pack and plugged spark plug in. Can't see a spark.
Is there an 'Ignition Control Module'?
Found what looks like an ignition control module in the intake area. Bosch 0 227 100 211. Can they be tested?
Last check was I have +12V on ignition coil.
As far as I know, spark is generated by 'closing' to ground.
Found that the 1.8T AEB (just like the 2.8 I have) DOES HAVE a Ignition Control Module (sits (like in the 2.8) on the airbox, with cooling fins inside the box; 1x 4pin out, 1x 5pin (middle is ground) in.
Cylinder 3 shows different value (put 1.5 Volt on inside between ground and the 4 cyl, measured output voltage).
Looks like my ICM is bad.
Part number is
Bosch 0 227 100 211
Will look for one.
Part number is
Bosch 0 227 100 211
Will look for one.
Part number is
Bosch 0 227 100 211
Will look for one.
Part number is
Bosch 0 227 100 211
Will look for one.
steve77
07-24-2007 05:04 AM
jurq
05-04-2006 05:44 AM
heateris
12
02-01-2006 01:29 PM
:::EuroRacerGT:::
11-04-2000 04:42 PM
