Misfiring... was misfiring before changing plugs, and now it continues. Multiple cylinders.
Plugs are properly torqued, gapped, etc. I would lean towards a coil or ICM, but it's on multiple cylinders. Thoughts?
Address 01: Engine Labels: 058-907-55x-AEBN.lbl
Part No: 8D0 907 557 P
Component: 1.8L R4/5VT MOTR HS D07
Coding: 06201
Shop #: WSC 06335
6 Faults Found:
16684 - Random/Multiple Cylinder Misfire Detected
P0300 - 35-10 - - - Intermittent
16687 - Cylinder 3: Misfire Detected
P0303 - 35-10 - - - Intermittent
P0300 - 35-00 - -
P0303 - 35-00 - -
16686 - Cylinder 2: Misfire Detected
P0302 - 35-10 - - - Intermittent
Readiness: 0000 0000
Coding: 06201
Shop #: WSC 06335
6 Faults Found:
P0300 - 35-00 - -
P0303 - 35-00 - -
I had the same thing happen after an engine rebuild. The coils were fine before I pulled the Motor but after re installation, I got about 16 codes. The all were caused by 2 bad coils. I replaced those two and a third failed that week. If it turns out to be your coils I would replace them all. Autozone has them for $32 and they have VAG stamped on them.
coil pack. It's those transistors (well, the wiring to them) that have the tendency to fail.
so I swapped the coil on cyl 3 with the one on 4. Cleared the codes with vag-com but the same code came back. So I ended up replacing the ICM. Originally went to a local dealer and was quoted over $300 for it. Almost laughed at them. Got it at autohausaz.com for about $130 or so. There's also a good writeup on how to test the ICM. Do a search if you need it. My car is am early 99 A4 1.8TQM.
