More about headlight washer, need help...
I got the entire diagram of the electrical wiring for the relay to pump. There is no power coming out of the relay to the red/lilac wire, or to the pump. However the relay seems to click on once for the windshield washer and the second time for the headlight washer. Is is possible that the relay is still Kaput?
Thanks for the help...<ul><li><a href="https://forums.audiworld.com/a4/msgs/2189080.phtml">For fuller story</a></li></ul>
the windshield/headlight washer while you test for continuity in the positive wire that you disconnected from the pump in step one using a ground other than the ground wire that was originally on the pump. If there is continuity then use the ground wire that you disconnected and test the positive wire again then if there is continuity you know that the relay, the positive and the ground wires are good an not compromised.
Nova Scotia A4
05-16-2006 01:36 PM
tkl999
06-12-2005 10:03 PM
ItsOnlyAComp
05-28-2005 10:50 PM
