More people on here should consider doing this... Battery Relocation!
#11
10 feet of 10ga cable has to weigh a minimum of 10 lbs. your set up will not meet track standards for relocated battery. someone did the math on this and came up with 75 pounds of extra weight. my car weights around 3200 lbs. so you're asking me to add 2% to get a 1% better front/rear weight distribution. putting a bag of sand in the trunk will do this at no cost. also battery on the left causes a right to left imbalance. mounting it on the right has problems with the gas tank. i don't know what a PDI is.
#15
The reason for this is because the box must be sealed from the driver. Also to keep any objects in the trunk from making contact between the 2 battery posts.
Why do you think there are a ton of different "sealed" battery relocation kits on the market?
#20
Car handles better as a result. Weight not that much of a consideration as it is only 3000lbs wet.
