must i remove the caliper to change rear rotors?
stfa
i have a quattro. do you have to remove all the brakes or does that 2-bolt carrier bracket come off with everything in tact?
someone must've encountered this before
thanks
thanks
You need to remove the carrier. It's two bolts
Taking off the caliper makes it easier as it is also a two-bolt job.
remove caliper, remove carrier, replace rotor, install carrier, install caliper.
Done!
wasn't that easy
Done!
wasn't that easy
Keeper of the Cash
Yes, two bolts for the caliper, two for the lock carrier
The rotor can often rust to the hub too. My solution for that was to spray the backside with Liquid Wrench, let it soak for 2-3 minutes, then beat the living **** out of it from the back. My left side was rusted on, the right side fell right off. Go figure.
Azncrombieguy
09-28-2004 09:35 AM
rklutts
09-15-2001 11:28 AM
