My "aliens" don't work, questions...
I noticed today my headlight washers don't work. Yet my windshield washers do. Is it more likely to be the pump or a fuse ? How hard is it to get to the pump? I assume it is the vertical object that sticks into the bottom of the washer tank?
You have the owner's manual, presumeably - tells you where all the fuses are.
If STILL get nothing, then two likely problems
a) line popped off washer jet (happened to me, and couple others). Sure sign of this is if you try to fill reservior to top, and you flood the garage.
b) Pump is bad.
b) Pump is bad.
My headlight wahsers don't work. Not fuse. Two at the same time. No visible demage. Any suggestions?
brat2.ua
06-03-2005 01:09 PM
