my 2.8-30V sounds like a diesel when warm
My 99.5 has 49K, after driving about 45-60min local and freeway, the engine sounds like a diesel during stand still acceleration. click/cluncking noise, it really sounds like a diesle car.
I've tried the oil cleaner and I've been using Mobile 1 (5-30W) since 32K.
the oil level is little above the middle section, always below max.
What else could it be? do I need to change or adjust the tensioner/timing belt this soon?
I've also notice a oil seaping spot on the engine tray towards the trans/engine area during oil change. Could it be the cam seal again? Replaced under warranty at 25K I think.
thanks in advance.
thanks in advance.
Is it a tough job to DIY? or should I get a Audi mechanic to check it out then buy the parts needed for them to do the install?
thanks
thanks
Although it only talks about removing the seal. Replacing the tensioner is a bit harder because of the chain. It has little slack and you have to twist and turn it outta there at odd angles
kkii9
02-26-2005 05:47 PM
