My ABS light is on again after rebuilding the module...... but it's a sensor now......
Light is on solid with no "brake" light or beep. Just the ABS light.
Vag-Com indicates it's the drivers side sensor intermittent trouble short to B+ or something or other.
Search didn't show much, but it did seem to rule out any problem with the module? Can anyone verify that?
We've had a lot of rain and it did happen after driving through some big puddles. Should I ignore it if it comes on a few more times or?????
My brakes need to be done anyway....
You might have a faulty connection or a dead sensor. My friend has a bad connection and I'll probably have to patch the cable to fix it.
I'd take the wheel out and check the cables.
But just make sure you dont break the sensor, since it seems that alot of people do this while channing brakes and rotors.
f3d
12-18-2005 09:33 AM
