my ac is acting up not sure if its normal
i refilled my ac system and now it seems to turn on and off all the time and is making it hard to drive the car. any ideas on what it could be?
one on the pressure switch saying it was out of limits or grounded, the other was on a flap. i rest the codes then tryed a test came back with a pressure switch code went through the reading blocks and the code was gone. so now i dont know what to do its working now but i still want to check the switch does any one know where it is located?
VAG-COM Version: Release 311.2-N
Control Module Part Number: 8L0 820 043 D
Component and/or Version: A4 KLIMAVOLLAUTOMAT_D75
Software Coding: 04142
Work Shop Code: WSC 06335
2 Faults Found:
01274 - Air Flow Flap Positioning Motor (V71)
41-10 - Blocked or No Voltage - Intermittent
00792 - A/C Pressure Switch (F129)
31-10 - Open or Short to Ground - Intermittent
4 Faults Found:
00601 - Potentiometer On Positioning Motor for Central Flap (G112)
09-00 - Adaptation Limit Surpassed
00600 - Potentiometer On Positioning Motor for Temperature Flap (G92)
00604 - Potentiometer Positioning Motor for Air Flow Flap (G113)
2 Faults Found:
4 Faults Found:
QuattroDrive
VAG-COM Discussion
06-18-2006 03:56 AM
QuattroDrive
07-15-2005 04:07 AM
