My CEL codes... what do they mean?
Hi everyone.. long time listener first time caller...
VAG-COM Version: Release 311.2-N
Control Module Part Number: 8A0 959 655 D
Component and/or Version: Airbag V AUDI D00
Software Coding: 00127
Work Shop Code: WSC 63342
1 Fault Found:
00588 - Airbag Igniter: Driver Side (N95)
32-10 - Resistance too High • Intermittent
Control Module Part Number: 8D0 906 266
Component and/or Version: 2,8l V6/2V MPI OBD2 D01
Software Coding: 01201
Work Shop Code: WSC 06335
2 Faults Found:
16785 - EGR System: Insufficient Flow
P0401 - 93-00 - Unknown Error Elaboration
16845 - Fuel Level Sensor Circuit: Implausible Signal
P0461 - 68-00 - Cylinder 1
Control Module Part Number: 8D0 820 043 F
Component and/or Version: A4-KLIMAVOLLAUTOMAT_D64
Software Coding: 00062
Work Shop Code: WSC 00000
3 Faults Found:
00603 - Footwell/defroster Flap Positioning Motor (V85)
41-00 - Blocked or No Voltage
01272 - Positioning Motor for Central Flap (V70)
41-10 - Blocked or No Voltage - Intermittent
01274 - Air Flow Flap Positioning Motor (V71)
1 Fault Found:
2 Faults Found:
3 Faults Found:
Footwell/defroster Flap Positioning Motor, Positioning Motor for Central Flap and Air Flow Flap Positioning Motor have turned around and exclaimed "Hey now, where is our voltage supply?" They did get it back eventually.
This has happened at least once since the last time DTC memory was cleared.
I'd get that airbag code checked out over on the VAG-COM boards. I'd also check/clean the grounds on the car/battery.
HTH
cmonster
HTH
cmonster
OneEighty
05-27-2003 06:28 AM
