my heater/ac is possesed by demons.
the air kicks in when i first start my car and then a minute later it dies out and just stops blowing air from any of the vents and it won't work no matter if i reset it. I have no idead what it could be. I'm thinking of getting my radiator flushed because I'm thinking maybe something is clogged.
It is doing what you are telling it to do. If you set it to 75 degrees then the auto climate control will begin blowing 75 degree air when the car is warm enough to produce the set temp. It does not matter in summer because the air conditioner can always produce cold air if you have your temp set to cool down the hot environment---regardless of the engine temperature.
nischal
11
06-20-2007 04:41 PM
My 4 Rings
01-06-2004 05:15 PM
J.Russ
10-25-1999 01:08 PM
