My intake has no heat shield and im pretty sure it is just making my car slower.
should i just make a good heat shield? I dont have my stock airbox to re install so i need to work with the intake system. also does anyone have a write up or instructions on making a nice heat shield?
thanks
thanks
use aluminum and get a decent rubber surround that can seal between engine and hood... for the most
part... oh and you might want to use cardboard so you can create a design and know where to cut.
Check out "Cascade Hoodliner".......a heat insulating foam similar to Dynamat but better.........
I used it to improve the heatshielding of my Lltek intake, and it works very well. Check out my pic poster.
so you still have the air scoop installed from the stock setup?
im talkin about te piece that screws on to the font the funnels the air t the intake. I dont have that piece installed anymore. that would probably help.
