My mechanic is saying that 0w-30 is awfully thin for the summer to run ...
Old 04-10-2006, 04:44 PM
Member
mattarios2's Avatar
Default My mechanic is saying that 0w-30 is awfully thin for the summer to run ...
could it cause any harm? I doesnt get hotter than 95 degrees here if that matters. Maybe 1 or 2 days it will hit 100. Anyways is 0w-30 too close for comfort in the summer?
Thank you, last post about oils for a while i promise :-)
Old 04-10-2006, 04:50 PM
New Member
A4SilencE's Avatar
5w40 is always a good way to go...
Old 04-10-2006, 04:51 PM
Junior Member
tkarwin's Avatar
I run 0w 40 the whole year.
Old 04-10-2006, 04:58 PM
Member
mattarios2's Avatar
Where do you live?
Old 04-10-2006, 05:02 PM
WJM
WJM's Avatar
rtfm
Old 04-10-2006, 05:03 PM
pac1085's Avatar
supposedly GC is closer to a 40 weight
Old 04-10-2006, 05:20 PM
Member
mattarios2's Avatar
Default the manual doesnt state that GC runs like a 40 weight and besides that
I don't have a manual, imma need one.
Old 04-10-2006, 05:26 PM
Member
mattarios2's Avatar
im waitin 4 audi junkie 2 chime in
Old 04-10-2006, 05:44 PM
Junior Member
tkarwin's Avatar
Portland Oregon
Old 04-10-2006, 06:09 PM
JWG
Member
JWG's Avatar
Default How high do your oil temps get? Have you considered beefing up your oil cooling system . . .
and then running a lighter weight oil?
Someone last year posted some nice shots of a complete RS4 oil cooling system upgrade with the front mounted oil cooler.
Also, which 0w-30 or 5w-30 oil you use makes a big difference, as 30 weight oils have widely varying wear resistence based on temperature. What HTHS numbers do the 30 weight oils on your "list" have?
If you run a very high quality 30 weight oil and have a good oil cooling system that keeps your oil temps low during summer, you may have the ability to run a 30 weight oil, because it will not break down under temperature--thus continuing to protect your engine adequately.
Also, what type of oil consumption do you see in your car? Lighter oil will likely increase oil consumption.
Quick Reply: My mechanic is saying that 0w-30 is awfully thin for the summer to run ...
