My odometer reads: Service INSP...WTF is INSP?
I just noticed that the bottom part of my odometer reads Service INSP. It keeps blinking for about a minute after i start the car. I took it in for service at 30,000 and im only at 33,000 now. Can anyone help me or advise me?
it pops up the indicator on the display.
Ignore it until you can either get someone with vag-com to reset it or your dealer schedule.
Vic
Vic
This is for my 2.8 (should be the same):
During road test: :
- Check kickdown, braking, steering, heating, ventilation, Air Conditioning, power accessories, and electrical systems.
After road test:
- Engine idle speed: check.
- Engine: check for leaks.
- Automatic Transmission: check ATF 1) .
- Power steering: check fluid level.
- Exhaust system: check for damage or leaks.
- On Board Diagnostic system: check Diagnostic Trouble Code (DTC) Memory with Scan Tool (ST) VAG 1551 and erase If necessary.
1) Severe conditions, such as extremely high temperatures, continuous mountain driving, trailer-towing, predominantly stop-and-go traffic conditions, it is necessary to change the ATF every 48,000 km (30,000 miles).
48,000 km (30,000 miles) and 96,000 km (60,000 miles)
- Engine: change oil and replace oil filter.
- Service Reminder Indicator: reset.
- Battery: check electrolyte level, add if necessary.
- Air Cleaner: Replace Air Cleaner Element.
- Cooling system: check coolant level and add if necessary.
- Dust and pollen filter: replace.
- Spark plugs: replace.
- Automatic shiftlock: check operation including Park/Neutral Position Switch.
- Manual transmission: check for leaks.
- AutomaticTransmission final drive: check level, add if necessary.
- Plenum water drain valve: check, clean cowl if necessary.
- Tires and spare: check condition and pressure.
- Brake system, check for damage and leaks: check brake pad thickness; check brake fluid level.
- Brake fluid: replace every two years regardless of mileage.
- Front axle: check dust seals on ball joints and tie rod ends, check tie rods.
- Sunroof: clean and lubricate guide rails.
- On Board Diagnostic system: check Diagnostic Trouble Code (DTC) Memory with Scan Tool (ST) VAG 1551 and erase if necessary.
During road test: :
After road test:
kodeTT
04-19-2004 01:33 PM
spicnspan320
11-24-2003 08:55 PM
Dauner
01-16-2002 09:49 AM
