My plan: Hook up my E-Code city lights to a switch like the fog switch where the ESD switch would go
If I were to have ESD, which I don't so it's blank. Has anyone put anything there, or installed a switch like I am planning? I assume I can just order a replacement fog light switch from the dealer that should just pop right into that spot, then just wire it up to get power and presto, I can turn on ONLY my city lights! I know I could just wire them up to my parking lights, but I would like to keep them seperate.
Or maybe I should do the front foglight mod, so I can turn them on w/out my headlights, and have the city lights come on then too...hmmmnnnn...can you tell I'm bored?
Thoughts, opinions?
Thoughts, opinions?
When you order it, don't forget to also order the connector plug otherwise its nearly impossible to solder on any wires.
If you get a foglight switch instead of the esp switch, it won't match the contour of the dash cutout. Also, the esp switch has six pins... only three are used, one is neutral, one of normally open, and the other is normally closed. It is a momentary switch so you will need to use a holding relay to keep the lights on. I didn't need a relay because I use it to "momentarily" mist my intercoolers.
good luck
good luck
you wouldn't happen to be in the Bay Area would you!?
Thanks again :-)
Thanks again :-)
SpeedyDTP247 CQ+UrS4
12-18-2007 12:40 PM
PanTTher
11
07-27-2004 02:32 PM
HDClown
11-20-2002 03:39 PM
gtittles
13
11-07-2001 05:49 PM
