My Ride (Recent Pics)
Old 08-17-2000, 10:19 AM
  #11
New Member
White BMW 330I's Avatar
Default Ace Desires 17"X7" ET35 23.58Lbs. Also Available in 18"
<center><img src="http://home.att.net/~amitch1/images/wkrim.jpg"></center><p>They really look sweet while in motion.<p><IMG SRC=" http://home.att.net/~amitch1/images/sigpic.jpg">
98.5 1.8TQMS 17" Ace Desires, Y2K Projector Mod, more to come.<ul><li><a href="http://www.acealloywheel.com">Ace Alloy Wheel</a></li></ul>
Old 08-17-2000, 10:21 AM
  #12
blueT28EnYcEe's Avatar
Default For me...yes..cuz i'm an impatient S.O.B....heres my advice
for minimal damage...make sure you use a 5/64 bit like it says in the FAQ...don't just find any drill bit laying around....make sure it's 5/64...after you eat enough of the tab so that it's even with the back...see if it will slide out...if not...drill a little bit more...and repeat this process...its really not as bad as it sounds...sorry if i got some people paranoid...like i said...im just very impatient and I went at it like I was drilling Armageddon...Good Luck!! (Be steady and patient!)
Old 08-17-2000, 10:25 AM
  #13
New Member
Default It is the Sport Suspension. I plan on lowering it but I dont want too low of a drop or a harsher..
ride. Any Recommendations?
Also, I dont want to spend more than $750 on the suspension parts (not including labor).<p><IMG SRC=" http://home.att.net/~amitch1/images/sigpic.jpg">
Old 08-17-2000, 10:29 AM
  #14
Ron_C's Avatar
Default It's really easy. As it turns out, it's like tin foil. Be very careful!
<p><A HREF="http://registry.audiworld.com/audi/registry/details.asp?car=5103" target="Resource Window"><img SRC="http://pictureposter.audiworld.com/AudiWorldPics/2000/Ron_Csig.gif" alt="Click for registry entry" Border="0"></A>
<B> -Ron, CT</B>
Old 08-17-2000, 10:31 AM
  #15
New Member
Default Will a 3/32 Drill Bit suffice? That's all I haveā€¦ I'll buy the 5/32 drill bit, if necessary.
Old 08-17-2000, 10:34 AM
  #16
New Member
Default Oops, I meant to say that, I'll buy the 5/64 drill bit if necessary. Sorry
Old 08-17-2000, 10:37 AM
  #17
Default do u mean 3/64 and 5/64???...if so...yes..the 3/64 will do the trick...reason
is because the diameter of the 5/64 bit is the same size as the tab making it easier to drill it away...so going a little smaller to 3/64 wont make much of difference anyways
Old 08-17-2000, 10:38 AM
  #18
New Member
MikedaPimp's Avatar
Default One word of advice....
No matter what suspension you put on it, make sure you get it set to the proper camber. I bought my car used as it was already lowered, and now I have to get a rim straightened because the camber was so off that it bent the rim. And plus, your tires will wear unevenly. I need new tires too =(<p>~Mike
<a href="http://registry.audiworld.com/audi/registry/details.asp?car=5694"><img src="http://pictureposter.audiworld.com/AudiWorldPics/2000/mycar.jpg" border="0" alt="98.5 A4 2.8MS 30v Silver/Black"></a>
Old 08-17-2000, 10:41 AM
  #19
PSS  //  Raj's Avatar
Default get Eurosport springs for 280, and bilstein shocks for 484 from shox.com. Total=764.
This is a bit over your limit, but you could then instead get H&R springs or others for less, and then bring the price down to low 700's. Labor would then be another 200 to 300. Those are sweet wheels BTW. I almost wish I had waited and got those. I know LLTek has a wheel very similar to that as well. It's a great design and a good choice on your part. Now lower it!<p>APR V.3,Remus,Eurosports,S4 17" Wheels
<a href="http://registry.audiworld.com/registry/details.asp?car=4776"> <img SRC="http://pictureposter.audiworld.com/Audiworldpics/2000/prashantrearsig.jpg" Border=0> </a>
Old 08-17-2000, 11:27 AM
  #20
clown-baby's Avatar
Default One problem with that....camber CANNOT be adjusted on the A4...
my camber is a little negative too after lowering with the H&R race...nothing you can do.<p><I>2000 1.8TQMS Santorin/Ecru </I>
<B> MODIFICATIONS: </B>
Eurolit3 bulbs
H&R Race springs
<img src="http://pictureposter.audiworld.com/AudiWorldPics/2000/idmodul_logo.gif"><img src="http://smilecwm.tripod.com/ut1/mgwhore.gif">
Quick Reply: My Ride (Recent Pics)
