My stumbling, surging, misfiring car is fixed!
Old 04-09-2003, 07:57 AM
  #11
Mr. White's Avatar
Default did you try measuring the resistance across the spark plug connector???
There are lots of solution tests in the cd manual, but i'm not exactly sure what it's talking about. It's not very clear. Did you happen to read those? and if so, can you explain them. Do you have the cd manual?
Old 04-09-2003, 08:01 AM
  #12
Mr. White's Avatar
also...didn't your car drive really rough? almost like there is no power??
Old 04-09-2003, 08:08 AM
  #13
ArandA4's Avatar
The removable part between the coil and plug.
Old 04-09-2003, 08:14 AM
  #14
Member
randy@5280's Avatar
Default Oh man... It was really bad at lower RPMs...
Up higher in the revs it was much better. At idle, the car felt fine- You'd have never known there was a problem just sitting in the car idling.
Never got around to measuring resistance on anything. I don't have the Bently manual, so I was a little limited in testing values and what not with the electrical stuffs...
Old 04-09-2003, 08:18 AM
  #15
Mr. White's Avatar
i didn't know it came off the coil. I may have to try that...
Old 04-09-2003, 08:23 AM
  #16
Elder Member
chipstar-32's Avatar
yeah i could imagine
Old 04-09-2003, 08:38 AM
  #17
ArandA4's Avatar
I posted the p/n in infinity's thread yesterday. Try a search
Old 04-09-2003, 09:08 AM
  #18
WJM
WJM's Avatar
Default probably just coilpack
I had to replace on on my 99.5
Old 04-09-2003, 09:10 AM
  #19
Mr. White's Avatar
so...can one misfiring cylinder cause another to misfire???
Old 04-09-2003, 09:26 AM
  #20
Member
randy@5280's Avatar
Default I wouldn't think so....
When you switched the pack from #2 to #3 did you VAG in between to clear codes? If not- You might see the old #2 misfire and a new DTC for #3. If you did VAG in between to clear DTCs, and saw a misfire in 2 AND 3, it's possible it could be both a bad coil pack *and* a bad power stage- The power stage would cause the misfire in #2, and the bad pack in #3 I'm thinking. I don't know what the likelihood of both going would be- But I'm thinking anything's possible? You mentioned that you cleared all DTCs recently and you're not seeing any new ones, right?
Quick Reply: My stumbling, surging, misfiring car is fixed!
