My wipers started to crap out on me. I took the assembly out and found the culprit
AudiWorld Expert
<img src="http://home.comcast.net/~day-o/wipermot3.JPG">
<img src="http://home.comcast.net/~day-o/wipermot15.JPG">
The shaft that you're looking at in the bottom pic that's covered in dried crud and corrosion is the spline that the driver's side wiper arm attaches to (pardon the mess on my work bench). When I disconnected the passenger and driver side linkages from the motor, the pass side would rotate freely in the assembly, but the driver's I couldn't move at all. Even knocking the lever arm with a BFH barely budged it. I had to PB Blaster the shaft and beat the thing out of the assembly to be able to clean and lube it properly.
Once I cleaned and lubed it up, they were back to normal. If anyone's interested I can post a detailed write-up. The one in the tech section was helpful, but doesn't have any pics.
AudiWorld Expert
Writeup for fixing slow wipers, specifically for a 2001 A4. Text appears above the reference pics, unless otherwise noted. Standard DIY disclaimer applies.
Tools / Supplies:
8mm socket or nut driver
10mm socket
13mm socket
2" socket extension
Small flathead screw driver
Medium flathead screw driver
#2 Philips head screw driver
Soft wire brush (I used a brass bristled brush)
Grease
Time: @ 1 hour
Difficulty: 2/10
Begin by stalling your wipers in the verticle position. Remove the battery/rear firewall cover. Using a small flathead screwdriver, pop off the wiper arm spline covers.
<img src="http://home.comcast.net/~day-o/wipermot1.JPG">
Using a 13mm socket, remove the retaining nut that holds each wiper arm to the spline.
<img src="http://home.comcast.net/~day-o/wipermot2.JPG">
Once the nuts are removed, carefully rock the wiper arm using an up and down motion as you pull up on the arm at the mounting point. Do not rotate the arms in a wiping motion or you could strip the splines. When you have both arms off, remove the plastic cowl by undoing the four quarter-turn plastic philips screws. There's also a metal clip at the end on the drivers side (visible as the rusty square below and right from the wiper arm in the above pics).
With the cowl removed, the entire wiper assembly should be visible. The assembly is held in with 3 10mm bolts and an electrical harness. The three bolts are circled in red, and the harness is circled in green. Undo the 3 bolts. Unless you have infant hands, don't try to undo the harness just yet. There's at least 6" of wiring behind it that makes undoing it easier once the whole assembly is out of the cavity (via a later step).
In order to pull the assembly from the cavity, you'll need to make some room, because the wiper motor that's mounted on the back of the assembly is about the size of a can of Campbell's soup. To make room, remove the engine ECU cover, which is held in place with a few 8mm screws. At this point, You should have something like this. (obligatory beer shot)
<img src="http://home.comcast.net/~day-o/wipermot6.JPG">
Now you should have room to work the assembly out of there. It might try to catch on the mounting points at the ends, so be persistant, and use different angles. I took mine out by freeing the pass side of the assembly first. Be mindfull of the exposed ECU and components. Don't knock them around. Now with the assembly out of the cavity, it should be easy to reach the electrical harness. Press the release button on the harness and disconnect it.
<img src="http://home.comcast.net/~day-o/wipermot7.JPG">
Take the assembly over to your workbench for the troubleshooting (don't mind my mess). Here it is, in all of it's glory. The motor is mounted in the middle. As it turns, it pushes/pulls on the linkage arms, which then push or pull on levers that are mounted to the splines. (NOTE: I think I have the direction of rotation of the motor in the middle going the wrong way. It should turn clockwise.)
<img src="http://home.comcast.net/~day-o/wipermot8.JPG">
At this point, I noticed some crud on my splines, so I took the opportunity to clean them using some WD-40 and a brass bristle wire brush. Remove the rubber caps from the splines and start cleaning. Don't damage the splines while scrubbing them. They're pretty delicate.
<img src="http://home.comcast.net/~day-o/wipermot13.JPG">
<img src="http://home.comcast.net/~day-o/wipermot14.JPG">
To troubleshoot where my wipers were binding, I disconnected the linkage arms from the center motor. I used a flathead screwdriver to lever the plastic ends out of the ball joint. Both linkages are mounted to the same balljoint. During dissassembly, the passenger side linkage is removed first, then the driver's side.
<img src="http://home.comcast.net/~day-o/wipermot9.JPG">
Once the linkages are free from the motor, the splines "should" be free to rotate in their housings. I was able to actuate the passenger side just fine with no effort, however, my driver's side wouldn't budge. It was ceased pretty good. I even pounded on the lever arm with a BFH to try to free up the spline shaft, but that didn't do any good either. That wiper motor has to be pretty powerful to be able to move that thing as slowly as it did.
Now that I've identified where my binding was coming from, I also wanted to test the wiper motor to make sure it wasn't damaged or burned-out from making that ceased spline move. Plug it back into the electrical harness and make sure the assembly is free from obstructions. Turn on the wipers. Mine worked like a champ, so I proceded to clean the ceased driver's side spline shaft.
The spline shaft is held in place by a washer and a circlip at the base of the splines. You can barely make them out in this pic. I used a small flathead screwdriver to remove the circlip. If you choose to take this approach, try not to stab yourself in the hand when it slips.
When you have the circlip and washer removed from the spline shaft, the only thing that's holding it in is friction. I used PB Blaster and a hammer to pound the spline out the back of the housing. Again, don't damage the splines. Thread the 13mm wiper arm mounting bolt back on, if your aim is that bad. Here you can see my spline shaft halfway out, and you start to see the corrosion that was going on inside. Also, the removed circlip retainer and washer are visible on the work surface.
All's that's left is to clean the shaft and the inside of the housing, followed by a generous lubing with some grease. Reassemble everything and reinstall it all in reverse order.
*NOTE: when working with any part of your car's electrical system, it would probably be a good idea to disconnect the battery. I did not do this, and got lucky. Fate was with me. Have your radio code handy before you disconnect the battery.
Tools / Supplies:
10mm socket
13mm socket
2" socket extension
Grease
Time: @ 1 hour
Difficulty: 2/10
