Need help on adding RCA preouts for Concert Radio
I have a 99 audi a4 1.8 without bose system. I'm thinking of upgrading my system but want to keep the concert head unit and changer.
Can someone help me out as to what I need to get (parts and from where) to add 2 sets of RCA preouts (1 set front and 1 set rear) from the back of the headunit (not from the speaker wires..but does it really matter?? )
Crutchfield has part name "127OEM2" but I'm not sure if this is the right part. Can someone help me out pleazeee....
TIA
TIA
Re: Need help on adding RCA preouts for Concert Radio
I used them and my installer had them lying around. I guess they came with all the Blaupunk Head units. I don't know if they still do come with the heads but if you find a Blaupunk dealer you might be able to score one cheap or for free.
P.S. I had a B*tch of a time getting altinator/ground noise out of the line. I had a PPI 40x4/200/1 and an Alpine V12 which did not produce the noise. Then I stepped up to a U.S Amps 75*4,200*1...and it just amplified the hell out of it. This amp is super clean and powerfull. So I don't know if it's just he amp or because of the power.
Moral of the story, It won't produce the same as a aftermarket head. So I wouldn't buy top,top,top of the line amp because you may create that which you try to avoid. Good luck
Ssri
NorCal Discussion
08-24-2006 07:18 AM
WL-UK
9
05-07-2003 01:38 PM
WL-UK
05-07-2003 08:41 AM
