Need help allen bolt on driveshaft....
started on the clutch R&R this afternoon. Taking my time since some of the other parts won't be here until Friday. Almost ready to drop the trans, but I cannot get the last allen bolt on the rear driveshaft loose. It is all the way on the top where I cannot get an allen wrench to it and I have already broken two allen hex sockets on this one bolt.
Any suggestions???
Any suggestions???
I have the triple square 6,8,10,12mm. the rear driveshaft is a 6mm allen.
Afraid of heating that area up, even though I know that heat will help break the loctite.
well if you rotate the DS so the allen is easily accessible, heating the area will not be a problem.
I've done it many times when the bolts have been too beat up to remove with an allen key....just plan to replace the bolts with new ones.
S4 in_lowplaces
19
01-30-2008 04:18 AM
RyanB5S4
11-02-2006 05:45 PM
Object
10-11-2001 04:25 PM
