Need Help: check engine light: small evap leak (intermittant) --- large evap leak
every time I clear these codes, they come back
within minutes. I already tightened the gas
cap, and the oil cap. What else could be
causing this code?
Is there any way I can diagnose the problem using
a VAG?
causing this code?
a VAG?
When they cleared my codes in the service drive with the VAGCOM, it gave suggested leak locations. I guess it's usually the gas cap, but it can also be hoses under the hood.
