Need help with DTC
I have this code that as come up, tried a search with no success, here it is:
VAG-COM Version: Release 311.2-N
Control Module Part Number: 8D0 906 266 B
Component and/or Version: 2,8l V6/2V MPI OBD2 D01
Software Coding: 01201
Work Shop Code: WSC 04750
1 Fault Found:
17912 - Intake Air System: Leak Detected
P1504 - 72-00 - Cylinder 5
What do you think the problem is,
Thanks,
Normand.
1 Fault Found:
Thanks,
Normand.
Few mouth back i had a similar DTC without the specific "cylinder 5". Do you really think it could be the idle valve?
I guess i'll be thinking about getting a new one.
Is the idle control valve only available at the dealer? how much$$
