Need Help with Fan Pulley Removal - Help
I have a 97 A4 1.8T. I am in the process of replacing the water pump. I have the front end of the car in the "service" position.
My manual instructs me to remove the fan pulley by using a spanner wrench to hold the pulley still while loosening the "central nut" between the fan clutch and the pulley. I DO NOT HAVE THIS CONFIGURATION. I only have a smooth surface between the fan clutch and the pulley. There is no nut or anything of that nature.
I am hoping that someone has "been here" and "done that".
Any help is appreciated.
I am new to the Audi engine so be patient.
you can remove that and take it all out. It's a good size allen head I think. It's easier to deal with the fan assembly on the bench.
Also IIRC it may be a reverse thread? Not sure on that, my Bentley manual is at the shop.
overly familiar with the fan assemblies on the motor. I have only had to deal with one on a 2000 1.8T and that was to simply remove it 100% and install a shorter belt. In that case it was one bolt coming in from behind.
* Viscous fan, removing and installing
1. Lock carrier in service position
2. Ribbed belt free of tension
- <b>Secure belt pulley for viscous fan with 5 x 60 mm bolt</b> and remove using hex socket wrench.
- Remove viscous fan.
- When installing viscous fan, tighten to 45 Nm (33 ft lb).
* Allen wrench will work instead of the bolt!
Insert it into a slot in viscous fan clutch assembly body and into the pulley.
Hope this helps.
<img src="http://img.photobucket.com/albums/v136/vladlesh/GetImage.gif" alt="Image hosted by Photobucket.com">
Hope this helps.
Minimization
10-06-2006 11:20 AM
russman111
02-02-2006 07:29 AM
Tourette(AFC2.812v)
12v V6 Discussion
02-23-2005 08:39 AM
