Need help with front brake replacement aftermath
This weekend I replaced the front rotors and pads with OEM parts. Now, my brake pedal seems to travel farther than I think it should, and it requires a lot of pressure to perform adequate braking. I've noticed that if I pump the brake pedal, it seems to do a better job of braking.
At no time did I bleed the brakes, open the lines, or leak/lose any of the fluid, so I don't think that should be a problem. Still, why does the pedal travel so far and not give a strong "feel"?
It sometimes takes a few pumps to get the caliper pistons to reset..
Try cycling the parking brake lever a few times to help the rear calipers seat, the fronts should only take a few pumps.
If that doesn't work, you may have blown a seal on the caliper pushing it back in. Check for fluid dripping from a caliper.
It sounds like the caliper pistons are retracting more than before..
It could just be that the intital clearances were wider than normal and once you position the pistons with a few stops you will be all set. It is also possible that the new rotors have a bit more runout (or an uneven surface coating) than the old which pushes the pads away further when you release the brakes and are moving. The OEM rotors come painted when purchased as parts. Did you remove that paint from the pad swept surfaces or you letting the pads burn it off?
Not smart, but I have burned the paint off through normal use. (more)
I drove it to work today (about 15 miles) and I'm still not happy with the pedal feel. I'm afraid I'll have to do some bleeding of the lines.
Re: Need help with front brake..break them in
The pads have to match the rotor, although they look smooth the brake pads needs to shape to the rotor to make full contact. Go to a parking lot and apply the brakes with moderate, not hard pressure till you feel them get better.
q2quest
12-03-2004 11:42 AM
q2quest
25
12-03-2004 11:29 AM
