Need help please my 98 a4 1.8t is smoking from the exhaust and doesn't run until 3k
Hi I really need help with my 1998 Audi A4 1.8T, the exhaust is smoking white smoke and when i hit the gas it tries to stall out, it only moves when i hit about 3k RPM it is a 5 speed manual, the codes showing up are
P1196- 02 sensors
P1545- throttle body module
P0134-02 sensors
I do not know if it needs a turbo, a new catalytic converter, or a new ECU ...the motor turns on and runs ..please let me know what do you think the problem is i would greatly appreciate your help i hate seeing my car just sitting and not running it sucks thanks alot ....
P1196- 02 sensors
P0134-02 sensors
Well your throttle body module is throwing a code, that will affect driveability.
Couldn't find your codes on the Ross-Tech site, but if your oxygen sensor is caput, you'll experience all that.
P1196- 02 sensors
P0134-02 sensors
P1196- 02 sensors
P0134-02 sensors
adaptation was completed using VCDS,but no smoking.
retlaw357
12-14-2010 06:19 AM
lag-sucks
03-11-2006 01:01 PM
