need help with readiness codes on an actron OBDII scanner..
i'm getting my car ready to go through emissions so I can finally reg it and all i've got is an actron obdII scanner.. it threw a code about the pre-cat o2 and i replaced that and now all is well there.. cleared everything and went out for a drive to generate readiness codes using the procedure on the 12th page of the linked .pdf below.. the actron scans "I/M Moniters" and i'm assuming the readiness codes are in there.. it lists catalyst moniter, o2 moniter, o2 heater moniter, etc.. they were all incomplete before i went out and when i came back from the drive they all said OK except for the "evap system moniter" which still says incomplete.. is that part of the readiness as well? and if so what can i do to speed along that test.. i was also thinking that maybe the scanner was just confused since all the other tests were completed. i'm working on getting vag-com, but until then this is all i've got. TIA<ul><li><a href="http://www1.snapon.com/display/DocMgmtDisplayFile.aspx?fileid=4671">http://www1.snapon.com/display/DocMgmtDisplayFile.aspx?fileid=4671</a</li></ul>
he recently passed here in Utah with 2 not-ready readiness codes. I believe they were for EVAP and cat efficiency.
Corrado79
VAG-COM Discussion
03-26-2007 10:56 AM
JohnelP
02-06-2007 11:27 AM
Crazy Quattro
08-19-2004 01:19 PM
201-A4
01-16-2004 10:14 AM
