Need Help with REAR S4 brakes...
Is anyone here running this set up?
I though the S4 rear brakes can NOT be used on the A4's.
I'm told that someone here is running that S4 rear set up(not the A8)....
If this is true....what parts do i need?
Calipers,brakets, rotors and pads???
Hand brake cables? S4 brake lines?
Let me know,
I have located a S4 in a salvage yard...Its a bring your tools and Pull your own parts...
Thanks
DG
Let me know,
Thanks
DG
Audi Enthusiast
that uses some S4 parts. Check it out.
GaryJ<ul><li><a href="https://www.audiworld.com/tech/wheel1.shtml">Tech</a></li></ul>
Audi Enthusiast
The tech article I referenced above suggests this may be neccessary - is the a model-year specific issue, or am I missing something from tech article (maybe the A8 rear discs are larger and cause this?). Thx in advance Rob,
GaryJ
GaryJ
It gets very expensive buying new stuff from dealer...also, Impossible to find a A8 in a salvage yard...So, S4 rear brakes, are the way to go....(if u ask me)
DG
DG
Audi Enthusiast
Uses S4 calipers and brackets and shows pics and an install - that's what I wanted u to look at.
