Need help with three fault codes, p1113 and p0441 and p1136. Please help me...
find the cause. manufacturer code fule air metering, evap emission control system purge flow fault, and the last, p1136, is the same as p1113. Thanks a million guys.
Re: Need help with three fault codes, p1113 and p0441 and p1136. Please help me...
actually it is a budies 2000 passat with the 1.8t automatic transmition. It was such a nice car when he bought, and now it is a piece of ****. He has 120k on it and still hasn't changed the timing belt. What a fool. I tell him all the time.
Thanks czand
Thanks czand
you will have better luck over at VWvortex forums...
you know..cuz it is a VW an NOT an Audi! It is true, some people on here may be willing to help..but you are better off posting this in a VW forum. Also, when you reply in the forum...change the subject line also.
J
J
Should be approximately the same ...
P0441 Evap purge valve ... Check Evaporative Emissions (EVAP) canister purge regulator valve
P1136 is a long term fuel too lean code. Check for vacuum hose leaks (false air), check MAF, etc. I'd especially look at the vacuum hose up to the FPR for splits or leaks ....
uber_ar
Audi allroad
03-22-2008 06:46 PM
crofTTy
10-15-2005 04:43 PM
Steviecef
03-17-2004 08:46 AM
