Never ending Build in Chicago
I haven't posted here in a long time, so I wanted to share my build. There's a lot of things I'm doing with my A4.
I want to thank Issam from INA Engineering for all his help
1- Build a Stroker Engine
2 - Wideband Conversion - AEB to AWM
3 - Car face lift
Stroker Build -
So far what I have for my build
ABA Forged Crank
82.5 Supertech Pistons
IE Rods - I-Beam
Precision 6057 Turbo
PAG Logger Manifold
3in Downpipe
3" Custom Exhaust - (Doing some changes)
38mm MVS Tial External Wastegate
ATP Fuel Rail
Fuel Pressure Gauge
044 Fuel Pump
Tial 50mm BOV
RS4 Throttle Body
044 Fuel Pump
ARP Head Studs Kit 058
ARP Main Studs 058
ARP Crank Bolt
Crank Rear Seal
Crank Gear Pulley
ARP Fly Wheel Bolts
Head Gasket set-(Big bore head gasket)
Main Bearing Caps Billet
Main Bearings w/Thrust Washer Set
Rod Bearings +.001" ACL calico coated
Fluidampr Harmonic Dampner
Turbo Cover
1000cc Fuel Injectors
Eurodyne Software
Supertech Valves
Cat Cam Springs
Titanium Retainers
Purple Cat Cams
Lifters
Timing Belt Kit
All Mounts
FX400 Clutch
Light Weight Steel Flywheel
Cat Cam Gear
TR1035 - Treadstone FMIC with 2 1/2 custom piping
034 Motor Mounts
034 Trans Mounts
034 Snob Mount with Bracket
JHM Drivetrain Stabilizer
Apikol Rear End driveshaft
JHM Solid linkage
JHM Shifter Stabilizer
B&M Short Shifter - with my own touch
I also bought another parts, but it's a surprise until I get it
For the wideband conversion I bought all the wiring harness from a 01 AWM A4 - I currently started working on this I'll post more information on how everything goes with the conversion.
Face lift -
I painted my RS4 bumper
Want to change the lower part of the rear bumper
Want to change the sideskits
I'm also painting my Boser
Changed rear shocks and installing Neuspeed racing springs
Changing to S4 brakes (front and rear)
S4 front and rear seats
Custom 3" exhaust
Here's pics of my car before I put my car in the garage
![](http://i94.photobucket.com/albums/l109/un1ko/DSC01026.jpg)
![](http://i94.photobucket.com/albums/l109/un1ko/DSC00955.jpg)
Here's how my conversion is going... Lol
![](http://i94.photobucket.com/albums/l109/un1ko/IMG_1301.jpg)
![](http://i94.photobucket.com/albums/l109/un1ko/IMG_1304.jpg)
Here are some pics of the parts I bought
![](http://i94.photobucket.com/albums/l109/un1ko/DSC01181.jpg)
IE I-Beam Rods
![](http://i94.photobucket.com/albums/l109/un1ko/DSC01033.jpg)
Presicion 6057
![](http://i94.photobucket.com/albums/l109/un1ko/Me022.jpg)
When I got my block from the machine shop
![](http://i94.photobucket.com/albums/l109/un1ko/IMG_0633.jpg)
![](http://i94.photobucket.com/albums/l109/un1ko/IMG_0632.jpg)
![](http://i94.photobucket.com/albums/l109/un1ko/IMG_0579.jpg)
![](http://i94.photobucket.com/albums/l109/un1ko/IMG_1107.jpg)
Thanks for checking out my post. More to come!!!
3 - Car face lift
Stroker Build -
ABA Forged Crank
IE Rods - I-Beam
PAG Logger Manifold
3in Downpipe
ATP Fuel Rail
Fuel Pressure Gauge
044 Fuel Pump
Tial 50mm BOV
RS4 Throttle Body
044 Fuel Pump
ARP Main Studs 058
ARP Crank Bolt
Crank Rear Seal
Crank Gear Pulley
ARP Fly Wheel Bolts
Turbo Cover
Eurodyne Software
Supertech Valves
Cat Cam Springs
Titanium Retainers
Purple Cat Cams
Lifters
Timing Belt Kit
All Mounts
FX400 Clutch
Cat Cam Gear
034 Motor Mounts
034 Trans Mounts
JHM Solid linkage
Face lift -
Custom 3" exhaust
IE I-Beam Rods
Presicion 6057
You mean the exacty same one BobQ sold to Rob which then had to buy a Autotech cam gear because he also owned a 058. He then tried to contact Bob about the issue and Bob would never answer or call him back. He ended up getting the Autotech cam hear from 034 which is the correct one.
The one on the bottom is what Rob got from Bob which is the 06A/06B cam gear, the top one is the he had to buy which is for the 058 block.
Picture from Rob's face book page.
![](https://a5.sphotos.ak.fbcdn.net/hphotos-ak-snc6/217608_792106430840_63900581_40035692_3650277_n.jpg)
The one you have is what 034 has on their site listed for the 06A/06B.
http://www.034motorsport.com/engine-...e-p-20106.html
Exactly why I asked, I do know a little about this stuff. lol
Looks like your going to have to buy a 2nd cam gear just like Rob did, good luck trying to get a hold of Bob seeing that he is pretty much blowing off everyone.
It's just BS that Bob wont even call me back. Thanks 034 for getting me the correct sprocket...
Will fit all Mk4 and B5/B6 engines with 06A/B style motor.
http://www.034motorsport.com/engine-...20v-p-795.html
I have onlyl seen one 1.8t cam gear listed on the CAT cam web site.
I know plenty of 06A A4 1.8t owners running that cam gear on their cars. Nearly all of the 058 owners I know of that run a cam gear run the Autotech.
Odd thing is the link you posted is to 034's inline 5 turbo 20 valve engine page.
You might just want to make sure you have the correct cam gear seeing that another 058 owner was giving the wrong one by Bob.
AUDI CTVW006 1.8/1.8T waterpump(ext) (-2000) 4 cyl-20v Mot.AEB,ADR
You learnt something new today
which uses the same camshaft gear as the AEB / ADR / AJL / 9A / PL / ABF / KR / ADU/ AAN etc. etc
CAT makes a camshaft gear that works with the 058 motor. Ruben measure the offset for me before you install it and I will tell you what model you have.
![Stick Out Tongue](https://www.audiworld.com/forums/images/smilies/tongue.gif)
yes Issam I know the 058 uses the same one, I have been runinng a Techtonics Tuning 16 valve cam gear on my A4 1.8t since 2003 ![Stick Out Tongue](https://www.audiworld.com/forums/images/smilies/tongue.gif)
Just found it odd that 034 lists the 06A CAT cam gear and the Autotech 058 cam gear on their 1.8t engine page but not the 058 CAT cam gear. It's not likely 1.8t owners are going to look on the inline 5 engine page looking for parts.
I just try to stay away from the CAT products as much as possible. lol
Last thing I would want is for the OP to have the wrong cam gear and end up destroying all his hard work.
Ok. So I installed the timing belt just to see if I would be off because of the CAT Cam Gear and it seems that I'm good to go. Everything lined up the way it suppose to.
![](http://i94.photobucket.com/albums/l109/un1ko/IMG_1440.jpg)
![](http://i94.photobucket.com/albums/l109/un1ko/IMG_1441.jpg)
![](http://i94.photobucket.com/albums/l109/un1ko/IMG_1444.jpg)
![](http://i94.photobucket.com/albums/l109/un1ko/IMG_1442.jpg)
I have a quick question and I was hoping someone can help me. I'm going to install this gear that connects to the IM shaft. Do I have to put grease? Are these the only 2 parts or am I missing something?
![](http://i94.photobucket.com/albums/l109/un1ko/IMG_1450.jpg)
![](http://i94.photobucket.com/albums/l109/un1ko/IMG_1448.jpg)
You do know the Fluidamper is designed for the 06A that uses 1 belt to run or are you mounting a 2nd pulley on it like you have in one of your other pics?
Just wondering if that is the solution to running the Fluidamper on the 058. I know another 058 owner that put one on his car and ended up shifting some things around and modified a belt to make it work.
