New alignment with adjustable Istook arms
Istook arms installed:
<img src="http://www.thebuzas.com/gallery/albums/userpics/10004/PICT0005%7E1.JPG" />
Just got it back from the alignment at Dave's in Huntington. We set it at:
2.25 degrees negative camber
6 1/2 degrees positive caster
1/16" toe out
Any comments on these specs?
Looks like this:
<img src="http://www.thebuzas.com/gallery/albums/userpics/10004/PICT0003%7E3.JPG" />
Might get some inner tire wear on the street. Luckily the car is only on the street for "test drives" and driving to the track.
<img src="http://www.thebuzas.com/gallery/albums/userpics/10004/PICT0001%7E3.JPG" />
Turns like a mother now... can't wait to get it back to the track.
1/16" toe out
Looks like this:
the tire doesn't care if it's toe'd in or out. either way, it's scrubbing to provide straight line
(highway) stability.
at static, yes, it's out, but when you dive into a corner on the track, it puts the toe near zero - which is the least resistant and quickest.
I have my car at zero (static) toe all around. I told my alignment guy that if he was a little off, to be out, not in.
i'd be concerned about directional change if a tire fails....
if your looking for quick turn in on the track try this: get a right hand drive steering rack flip it over and put it in your car. iirc this will give you reverse ackerman angle. just never let go of the steering wheel.
