new audi owner
i just traded my jeep cherokee for a 2000 audi a4 quattro 1.8t. has 144K new time chain , but today i went did spark plug change and oil change i seen alot oil on belly sheet. but question is i havent figered out how to turn on the foglight i cant find a switch and all
i ment timing belt my bad but when i changed oil i went and cleaned all oil up and going to drive it to work and back today and see if i can see any i am trying to find a way to install a oil pressure sensor to run to my pod anyone know a diy is or part i can order
so found leak from a cracked oil line went replaced it and well now i have a bigger problem i went under call check the rear shocks bec i was bottoming out and foudn a broken bar from sway bar im at work so cant upload picture but it looks like it been riding on my cv axel
They usually come on with headlights too. On my PFL B5 they extinguish on high beam also, but on that model they're within the same light housing so it's probably a heat issue.
so i figered it out the fog lights it a button works get has hids in it apparently got under car today and found it has borla catback on it so cool bec i was going to order one but this is the part i need to replace. also just ordered a test pipe for my car off amazon 80 bucks i know it gabble
That right rear link to the sway bar is part number 8D0-505-466 and runs 63.98 dollars. Plus about 10.00 shipping. It takes 2 days to get to us and then up to about 5 days at most to get to you. Once ordered on average it is 5-8 working days to get the part to you, within the US. Any questions please ask us.
magiciansampras
01-06-2010 05:22 PM
John Force
03-08-2001 05:16 PM
