no brake pedal
my brake pedal goes down to the floor with little resistance, I've changed the master cylinder and bled it properly then bled the entire system and still have no pedal. Any suggestions would help.
ABS has to be bleed using a VAG-Com. Clutch bleeding shouldn't effect brakes, but you could have got air in the clutch system when you changed out the MC since they share the same fluid reservoir.
Swank4
12-12-2005 04:59 PM
CGP
03-29-2001 08:32 AM
