Normal vs. Abnormal Power Steering Noises?
Reading too much on this board can get one paranoid! I'm seeing that a bunch of you had P/S failures, preceded by noises.
When I'm parked or moving very, very slowly, turning the wheel makes a very subtle low "wmmmmm" (best I can describe it) sound. I hear no noises at driving speeds and the the steering seems to turn fine without binding. And no leaks, P/S fluid is clear (green tint).
So, is that sound normal? I don't recall hearing it in other cars I've driven, but maybe I wasn't paying attention 'cause they've not been a problematic part.
Let me know if I'm goin' overboard with this, or if this noise is something I should be worried about.
Thanks,
Al
Thanks,
Al
my dads chevy makes that sound everytime you get anywhere close full turn left or right. it never happened in my audi until i got a leak in my PS and was low on fluid. adding more fluid made the sound go completely away.
and the rpms usually drop a little bit. Check the fluid level just to make sure. When mine gets low on fluid it usually makes a grinding noise when its cold.
Thanks, all. Maybe I'm just being paranoid. The fluid is up to snuf level-wise, so it's probably just the normal noises a rack makes. I'm saving up for a timing belt change so any other thought of a co$tly part is not something I want to entertain.
- Al
- Al
john in cincy
12
03-12-2007 01:45 PM
agentX
10-06-2005 07:13 PM
