Now that the new "Reformulated" Amsoil 5w-40 euro oil isnt as good as it used to be ...
Does anybody know what oil is better the 5w-40 euro amsoil or 5w-30?
Here's the specs, but I have no idea what they mean ..
5w-30 blend ...
Kinematic Viscosity @ 100? C, cST (ASTM D445)............................................. ...................11.8
Kinematic Viscosity @ 40? C, cST (ASTM D445)............................................. .....................63
Viscosity Index (ASTM D2270)............................................ ................................................18 6
Cold Crank Simulator Apparent Viscosity @ -25? C, cP (ASTM D2602)...................................<2310
Borderline Pumping Temperature ? C (? F) (ASTM D3829)............................................ ..........-44 (-47)
Pour Point ? C (? F) (ASTM D92)...
............-55 (-67)
Flash Point ? C (? F) (ASTM D92).................248 (478)
Fire Point ? C (? F) (ASTM D92)...............................262 (504)
Noack Volatility (DIN 51581) % weight loss (g/100g).................................7.4
High Temperature/High Shear Viscosity cP, 150?C, 1.0 x 106 s-? (ASTM D4683).....................3.5
Four Ball Wear Test (ASTM D4172B: 40 kgf, 75? C, 1200 rpm, 1hr) Scar diameter, mm...........0.33
Total Base Number.....................................11.0
or the euro blend ...
Kinematic Viscosity @ 100?C, cSt (ASTM D-445)
14.6
Kinematic Viscosity @ 40?C, cSt (ASTM D-445)
87.8
Viscosity Index (ASTM D-2270)
173
CCS Viscosity (ASTM D2602)
4500 @ -25?C
Pour Point ?C (?F) (ASTM D-97)
-48 (-54)
Flash Point ?C (?F) (ASTM D-92) 230 (446)
High Temperature/High Shear Viscosity @ 150?C , 1.0 x 106 s-1 (ASTM D 4683), cP 4.2
Four Ball Wear Test (ASTM D-4172 @ 40 kgf, 150?C, 1800 rpm, 1 hour), Scar in mm 0.40
Noack Volatility, % weight loss (g/100g) (ASTM D-5800)
6.6
Total Base Number
>12.0
Thanks guys and oh yah this is dealing with the 1.8t if neither of them compare to the other oils out there nowadays i think im going to go mobil1 or gc ...audijunkie swears by GC so i think ill hit that if need be
Thanks again
5w-30 blend ...
14.6
87.8
173
4500 @ -25?C
-48 (-54)
6.6
Total Base Number
>12.0
Thanks again
damn they want $7.30 a qt thats with the preffered customer ...
Is mobil 1 or gc a better alternative for cheaper junkie? What do you think?
And last question what oil do you recommend for my fathers 2.8 a6
Thanks for all your help once again
I like the 5-30 diesel oil, very very good stuff. I use it in my Cummins truck with bypass filter...
it stays sooo nice and clean and oil samples tested come back with a near perfect bill-o-health. ;-)
GC or 5w-30 Mobil 1 T&SUV for 1.8t. For the V6, pick an oil based on his driving...
Say, if he does all longer than 10 miles trips and drives like 10k a year, no reason not to use something as basic as Mobil Clean 10w-40 or Havoline or Syntec Blend. Cold-Cranking will not be an issue above -10f with those oils. I dunno what climate you are in, but if it's warm 15w-40 would do the same thing, with lowered consumption. 5w-40s are a luxury and frankly, not that spectacular in comparison to a good 10w-40 blend. High-Miles oils are probally best for the V6 with it's delicate seals. I use a lot of Castrol GTX HM. It's really thick. The 5w-30 GTX HM is totally fat for winters. It stopped consumption entirely on my Mother-in-Laws 12v A6. That is with a shot of 10w-40 HM in there too. The 10w-40 is really thick, thick enough to kill mpg, but will eliminate consumption...important in Sr citizen applications...no disrespect. So, yeah, if he likes changing oil (I skip the belly pan all together) plain old 10w-40, but HiMi oils offer so much for that engine, it's hard to NOT use them in this application. GTX HM...works. I get 2 big 5q jugs, one 5w-30 and one 10w-40 and use the 5w-30 until it's empty and top-off with 10w-40. The 5w-30 is very close to a 5w-40 anyway. Cold-cranking fun and seal conditoning for $2/q. 6000-8000 miles intervals if he does not do all short trips. 5w-40 is a waste of money and not that good.
lol, on a side note, I just picked up some Havoline 5w-20 for the Acura. I already have some Havoline Synth 5w-30 here, but it has no moly for break-in.
LOL You are still asking about this?! =-P
Elf Excellium LDX 5w40..I already told you how to get it through a distributor. Enough said. If you don't want to buy it by the case..you can get it in the link for $7 per liter. I get it for $5.50 per liter by buying it in cases of 18L. I have nothing more to say on the matter.
J<ul><li><a href="http://turbofrogperformance.com/Products/Engine/ELF_Oil.htm">linky</a></li></ul>
Try $4.95/qt at the time I bought my couple of case loads just a few months ago.
Remember, the website does not reveal the preferred customer discount until after you order. It will show the minimum suggested retail of $6.85 until you go well within the order confirmation process.
If you do not like the watered-down AFL 5w-40, go with the AMO 10w-40 Synthetic High Performance which is almost exactly the same as the old AFL 5w-40 in almost every specification and slightly cheaper.
The HDD 5w-30 is likely one of the world's best engineered oils and works well in just about all our Audi engines which still have good compression and oil rings. Upside = keep it in a normally aspirated engine that does not burn much oil for upto 20,000 miles without worry. Downside = it's pricy at between $6.45-6.75 per quart (MSRP of $8.75).
a5.cw
05-21-2019 05:10 PM
cpd
17
10-22-2006 07:15 PM
psuaudi
13
10-17-2006 01:15 PM
Oil Update..Picked up Castrol Syntec, Euro Formula 0w-30, made in Germany form Autozone..Hope to fix
DesmoTesta
08-29-2006 05:48 PM
The Mystro S4
04-13-2004 08:36 PM
