Occasional loss of boost, any ideas?
Occasionally, I won't be able to get more than 5 psi of boost. Normally, I see 16-17 psi spikes with my GIAC chip, but then all of a sudden its gone. I remember somebody saying a couple days ago that if the wastegate is stuck open, you wouldn't see more than 5 pounds of boost. It also seems that even when I am seeing normal levels of boost, my gauge boost gauge seems to pause at 5 psi for a split second before continuing on. Do you think that my turbo could be going, or do you think that it is something else.
I was thinking that it might be the BPV as well, but I thought that if it was bad, there would always be a problem. I can go a couple days without this happening once, but then it may happen once a day and only last for a couple miles.
