OEM RS4 front
<center><img src="http://pictureposter.audiworld.com/17876/rs4.jpg"></center><p>
Does this look right to you? Does this happen due to our car not having wide body? How many have actualy done OEM RS4 conversion from Achtuning?<ul><li><a href="http://www.achtuning.com/rs4frontbumper.html">http://www.achtuning.com/rs4frontbumper.html</a</li></ul>
I'm the type that needs to have his car be perfect to the last inch. I don't like Riger and SGI's cheap bulit quality. Untill now, I though ABT and Oettiger were my only options. But when I saw the OEM RS4 front, I had my mind set on it. What do you think?
But apparently, it's easily solved by cutting slits where it bows out...this will allow a little overlap, which should relieve the bowing. Seems easy enough...but who knows. If I were you, I'd go with the RS4....it can be "coerced" to fit well, if you have the right bodyshop. If you bought/buy it from Josh@Achtuning, I'm sure he'll let you in on all the little secrets to get it to fit perfectly. Good luck!
Andy
Andy
fourwheelslide
08-30-2004 10:41 AM
huwla
08-24-2004 08:03 PM
