Oil change question: oil drain plug was replaced without crush washer, mechanic mentioned something
#11
Imawesome, thanks for the offer, but i'm in NorCal.
Thanks for all the input, will try posting on NorCal forum to see if anyone could give me a live tutorial ...
Thanks!
Thanks!
#12
you know.. if you pay my gas to commute up to norcal .. i'll do that too.. still cheaper then 300$.. and I make my 20$
... Oil change really is simple. Especially on the 2.8L. I'm sure you'll find someone in norcal to help you out.
#13
We have sealed TRE'S, Control arms, sways.. everything. Look under your car.. and see if you find one grease nipple. Unless you have aftermarket sways (I think H&R comes with a grease nipple for it's bushing) you don't grease anything. Oil change costs me... 32$ total. 6quarts oil.. one filter. It's gotten as high as 40$. But I bought some damn good oil. I do my own labour so that kind of explains the cheapness but... You got ripped off.. I would go to the dealer and ask what the extra lube bullsh!t is about.
#14
On next oil change, just replace it. Finis. Without the crush washer, you may leak a small amount of oil from the drain plug, but it's nothing to really be concerned about. It will make a small mess on the belly pan which you can wash off with some Simple Green or other strong detergent and water.
If the prospect of a small leak bothers you, bring the car in for an "early oil change" and just do the above a lot sooner. I find it hard to believe that anything negative happened to the threads as a result of the washer being left out. If the threads are hosed, it's because the previous mechanic over-torqued the drain plug, not because of the missing washer.
Cheers,
Cheers,
#15
the bolt get embedded into the washer area when being tightened. I would recommend doing it yourself, get a crush washer (copper) and get a new drain plug, either the one with the magnetic tip or the one with a spicot. Both have added benefits over the standard bolt/plug.
#17
it's not because of the lack of washer. It's due to the incompetence of the person who tightened the bolt. I've watched a jiffy lube guy use an impact gun to replace an oil plug while I stopped in to pick up a customer's car they had broken.
Avoid these places like the plague.
