Oil change question: oil drain plug was replaced without crush washer, mechanic mentioned something
#22
AudiWorld Uber User
<center><img src="http://pictureposter.audiworld.com/42525/fumoto.jpg"></center><p>(crappy pic, I know) since the valve is threaded from end to end, unlike the OEM drain plug, it sealed up the leak that I caused by stripping the pan threads. $35 or so shipped and I never have to remove a plug again for oil changes. FYI, if you have a 14mm drain plug like mine, you will need to remove the turbo oil return line to install the valve, so have a gasket handy.
#23
AudiWorld Uber User
a fellow B5er pointed out that there is also an issue with the drain plug. It's not threaded completely and the washer does not compensate for the lack of threads. In the end, you are only using like 1/2 of the threads in the drain pan. That puts all the torque on only part of the aluminum threads and I don't know if I've seen another car with such a funny drain plug. I can't remember all the cars I worked on when I was a mechanic briefly, but of the 3 that I maintain now (Toyota and Pontiac, too) only the Audi had the partially threaded drain plug.
#24
Just put a new crush washer on, assuming Jiffy Lube used your oem drain plug bolt. I wouldn't put it pass them to forget to put it back in, and then install a drywall screw in it's place, when the previous owner came back to complain. :/
#25
now since you dont have one i wouldnt worry to much about until next oil change unless it leaks. if it does then its basically another oilchange or a quick removal of the plug. putting your gloved finger into the drain whole and replugging the screw with a gasket. either way i would skip the mechanic and DIY
#26
It's possible you haven't given us all the relavent data but based on what you have told us I'd have to say this guy is looking for some easy money. Go elsewhere.
#27
AudiWorld Uber User
you won't lose more than 8 ounces of oil. It'll be messy, but it won't be TOO messy
#30
I also forgot to empty the pan and since its only a 6qt one and already had 4qts of the oil oil I had a massive mess on my hands
Delta-9
09-13-2004 07:38 PM
javanator
07-08-2004 10:47 AM
Me_and_my_GT
03-01-2004 05:07 AM
BrianN
05-05-2000 03:29 PM
