Oil in coolant overflow
There is also what looks like sludge, but I guess it's oil in my overflow tank, is it a bad head gasket or a crack in the head itself, is there anywhere else where oil and water can swap?
oil change won't cause this on it's own. lack of maintainance on the cooling system causes the cooler to corrode. changing the filter was probibly the final insult. unit will need to be replaced and coolant system flushed!
The oil cooler is what the filter screws onto. To fix <A HREF="https://forums.audiworld.com/oz/msgs/2048.phtml"> LOOK HERE </A>
If you keep driving on the busted oil cooler then all your oil will drain into the coolant system, the coolant system will over flow. Then you will be left with no more oil in your engine. eeek. Im surprised your engine/oil light hasn't already come on.
Its not an expensive part.
that's why I thought it was just a bad seal on the new oil filter when he said it was the cooler, and I check my oil almost every day so i'm not to worried about an engine with no oil, but it did take about 4mm on the dipstick when it first happened
aj1soad
Audi A3 / S3 / RS 3
03-10-2018 09:00 AM
deabionni
02-07-2016 04:51 AM
S4Bum
11
07-05-2007 01:07 AM
cordoba quattro
02-16-2005 09:56 PM
