Oil Drain Plug stuck on 1.8t , someone please help.....
Today I went to do my first oil change on my own, but I can't get the damn drain plug off, its on really tight, I think last time it went to the dealership they overtorqued it. I really don't want to take it back to the dealership because of bad expirances there. I tried 10w-40 on it but that didn't work. Anyone have any suggestions thanks.
Re: Oil Drain Plug stuck on 1.8t , someone please help.....
If you have decent tools (read: not those stubby Craftsman wrenches), you should be able to get enough torque to loosen it up. When I did mine, it was tighter than I thought it needed to be, but I did get it off.
It may be a little easier when it's a little warm.
I just experienced the exact same thing... I went to Home Depot and a long box end and moderately swung a dead blow hammer at it. Loosened right away. FYI, nobody mentioned yet, but Do Be Careful. The oil pan is aluminum, and will strip if not respected!
The answer......
Use a jack to apply pressure to the wrench until it breaks lose. Slap the wrech on there, put a jack under the handle, and start jacking it up. Believe me, the wrench is not torque more than the 3000 pounds of your car's weight.
pac1085
07-01-2005 12:45 PM
ThorsHammer
03-02-2003 05:34 PM
