Oil extractors / power extractors
#11
doesn't seem like a true thorough oil change to me. I do it the normal way and pour a half qt of new oil through, for good measure, to clean anything left out while the drain plug is still off. That looks like a tool for the lazy! =-P
J
J
#13
however I feel that pulling the drain plugs allows more gunk or particulates to be removed from the system.
#16
i also use a motive power bleeder for the brakes.
you cannot interchange them as one is pressure, the other vaccuum.
if you are looking at a vaccuum bleeder for the brakes then you could use it for both purposes. my audi dealership switched to vac brake bleeders a year ago and the audi techs hate them. nate said it is much nicer pushing fluid than pulling it. quicker too.
#18
fwiw, boats use vac oil extractors all the time. it's not like they have a drain plug in the bottom of the hull.
regarding the particulate removal, it's anyone's guess. if there is a lip inside the pan around the oil drain then pulling the plug won't get everything out either. having never seen the inside of a b5 oil pan with my own eyes i can't say one way or another. i have, however sucked the oil out and then removed the drain plug and got only a couple drips. that -to me at least- means the pan was empty.
