Oil hot but engine running cool
Ive got a 1999 audi A4 B5 and when i first start up the car says the oil is already 250degress and when i drive it it will raise to around 300+ but the watertemp stays at normal temp. i just had to replace the timing belt idler roller cause the bearing went out in that and was doing some cleaning with some parts cleaner and i know the oil temp sensor is right between the crank pulley and ac pulley would it be possible i didnt completely clean off the cleaner and it ruined the senor? the car runs fine just seeing that gauge that high worries me.
AudiWorld Uber User
That's probably a broken oil temp sensor. Normally on a cold engine, the water temp will normalize long before the oil temp, and it's certainly not 250 degrees when you first start it. I would try the sensor first.
When you cleaned with the parts cleaner you provided another path to ground which causes the gauge to read high at start up. Unplug the electrical connector and and clean everything with contact cleaner.
Stonediggity
11
09-02-2008 07:52 PM
Lemon S
04-09-2003 07:19 PM
MarkK
02-26-2001 05:12 AM
