OIL LEAK!
If you had a 2.8 I would have more ideas. Anyway, assuming it's engine oil, power steering or tranny fluid, check the following:
-drain plug
-oil cooler O-ring
-oilpan gasket
-valve cover gasket
-crankcase breather hose (if 1.8T engines have that)
-head gasket
-front or rear crankshaft seal
-camshaft seals
-drain plug
-oil cooler O-ring
-oilpan gasket
-valve cover gasket
-head gasket
-camshaft seals
moribundman
12v V6 Discussion
05-21-2003 07:50 PM
gobble
12-14-2002 08:30 PM
