Oil Leak: Cam shaft Tension Chain Seals
Old 07-12-2002, 01:48 PM
New Member
jmglass2000's Avatar
Default Oil Leak: Cam shaft Tension Chain Seals
I have an A4 1999 with 40000 miles and just had a service where they found an oil leak in the cam shaft tension chain seals. The explanation is that the chain is under constant pressure and wears out the gasket seal. After about $750.00 in repairs (post warranty), I am a bit concerned. It seems early to have this type of wear. I noticed quite a few posts with similar problems, some caught earlier. And the dealer told me someone else had the same problem today, with even less mileage. The service rep said now they have made strides in getting better materials, so this won't wear out so quickly. The only prevention is frequent oil changes with good oil (perhaps). But, as I did the schedules maintenance at the dealer...
But, is this a defect or just working out the bugs in the engine?
jmglass
Old 07-12-2002, 02:30 PM
jkevermore's Avatar
I had the same at my last visit. MY2000 w/ 48k
Old 07-12-2002, 03:02 PM
New Member
NeverFollow's Avatar
Just got the same report on my 98.4 @ 48K. Anyone know what's it cost to fix?
Old 07-12-2002, 03:16 PM
New Member
mooks22's Avatar
Default Re: Oil Leak: Cam shaft Tension Chain Seals
had the same problem... the valve covers and the cam shaft closing were both leaking oil at around the same milage... my car is under warranty so it was fixed free of cost... but the mechaninc charged about 375 to the warranty company
Old 07-12-2002, 07:18 PM
brrman's Avatar
My '98.5 had the same leak after 60K miles. Didn't cost $750 to fix tho.. (around $350)
Old 07-15-2002, 06:31 AM
New Member
Default Re: My '98.5 had the same leak after 60K miles. Didn't cost $750 to fix tho.. (around $350)
Big difference in cost. The bulk of the cost was labor; the parts were maybe 5-60.The dealer claimed it was an 8 hour job according to the service manual. How many hours was yours?
jmglass
doublea2020
Audi allroad
03-23-2006 05:34 PM
pl212
10-02-2004 01:37 PM
vish
04-14-2004 05:23 AM
andre d
01-09-2003 05:13 PM
gg117
14
09-19-2002 07:21 PM
Quick Reply: Oil Leak: Cam shaft Tension Chain Seals
