Oil leak on the front of the engine (2.8L)
I have oil leaking on the exhaust manifold on the driver's side. I can't tell exactly where it is coming from, but I am pretty sure it is the valve cover gasket. It only seems to be dripping on the front of the manifold. I assume it is being dispersed by the fan since it is spread around a bit.
I am going to grab some valve cover gaskets from purems and am wondering if I should do the cam chain tensioner seals while in there. I don't think they are leaky. They normally leak in the rear of the engine don't they?
Heres a good write up from rob<ul><li><a href="https://forums.audiworld.com/a4/msgs/1650707.phtml">Write up</a></li></ul>
usmcB5
9
03-18-2008 03:44 PM
