Oil Pan Stuck - 1.8T AWM
Hello, I'm in the middle of changing my oil pan and it seems to be very stuck to the block. I have all the bolts removed (to the block: 18 small bolts, two large bolts, to the trans: two bolts plus one nut bolt). I pried/whacked the front of it off and I *think* that the rear section (towards the trans) is still "glued" to the block by the gasket sealant, but I'm not 100%. I have enough room to take it out if it detaches (trans/engine jacked up), but it just seems to keep pivoting on that one point. Any suggestions/ideas? TIA.
There are two of them mounted up by the transmission accessable through two holes? That would probably be it, but I don't recall seeing anywhere on the new pan to put another bolt?
HACK THS
06-18-2008 06:17 PM
Small Town Terrorist
09-12-2007 03:58 AM
heavens_drive
03-29-2004 07:18 PM
