Oil Pressure Light stay on... What would cause this???
I just changed out my dash cluster on my 96 A4 because my old one was missing a ton of lights and just about stopped working all together. Whe I put the new cluster in I noticed that everything now working including the dinging sounds... but when I hold it at about 2300 RPM the Oil Pressure Light goes on and stays on. I checked the oil level and it is only about 1/2 quart low.
What would cause this? How do I fix it?
and considering you just changed the cluster, I'd put my $ that there is something loose or disconnected behind there.
All the electrical conectors behind the cluster are all plugged in tightly.. nothing is loose. I also noticed that when taking out the old cluster that the Oil Pressure Light was removed from the cluster. Is there a Oil Pressure sending unit or a Pressure sensor somewhere on the car?
I'd replace the sender first (very easy) and/or check your pressure with a gauge. If everything's cool according to the gauge, the sender is busted.
I don't think the sender is very costly, IIRC.
jurq
01-31-2009 01:34 PM
GruvenS4
07-12-2005 09:39 AM
sochi
Audi 100 / A6 (C4 Platform)
03-31-2004 03:38 PM
