Oil sensor error, exactly WHICH sensors could this be reffering to...
2.8l with Tip
So if you follow my other threads, my big red oil pressure light is on, ALONG with the yellow oil sensor error/alert/warning.
From what I understand (please correct if I am wrong), the SENSOR on the bottom of the oil pan sends level and temp info to the display, while the oil pressure SENDER simply sends OK or NOT OK signals to the display, not actual bar values.
Could the error be referring to EITHER of these sensor/senders or just a specific one? Figuring this out will help me figure out which one to replace.
The good news is that there does not seem to be an oil pressure issue, so the sensor seems to be the culprit.
<center><img src="http://cloudcitydigital.com/lcd.jpg"></center><p>It's kind of hard to see there, but the text next to the little oil can reads "sensor".
wrong?
Did you check out what he said and found he lied or what?
Not trying to be a d*ck, but it seems from previous posts and responses that you got many suggestions for this already.
I didn't want to rehash it all, because like you said, we have been through most of it.
I now know the misfires were from oil getting in the plug wells due to a shredded breather hose, screwing up the vacuum and allowing oil to push past the gaskets. The hose is being replaced right now.
As for the oil sensor alert, yeah the guy said it had been yanked out when they were changing his oil, but I can't be sure about that.
I'm just trying to figure out which sensors that oil sensor alert can come on for, I purchased a replacement pressure sender, but don't want to have it replaced (from what I have a read, it's a fair amount of work), unless I know the sensor error could be attributed to that.
So yes, we did go through all this stuff, but I guess my question is more specific now:
Which of the two oil sensors/senders (level/temp & pressure) does that alert come on for?
to believe that is the sensor that's bad.
i guess its possible for it to be 'sorta broke' but... unlikely..
S4AVT
01-02-2006 07:55 AM
